BlindBrick 0 #1 July 23, 2004 Bak in the day, I heard mention that the Astra battery pack was not a proprietary item, but rather an off the shelf component that could be obtained at some hardware stores. I tried calling FXC, but the person that I talked too said they could only answer questions that weren't technical. Therefore, I was wondering if anyone here knows if that's true, and if so, what the model number or specs are. -Jackmc"If you end up in an alligator's jaws, naked, you probably did something to deserve it." Quote Share this post Link to post Share on other sites
riggerrob 644 #2 July 24, 2004 From FXC's website: Astra battery part number 811-00374 lithium US$45. voltage 9.5 when new and 7.5 when due for replacement At arm's length, Astra batteries are twined, similar to Cypres batteries. I have an Astra at work and will try to send you more details tomorrow. Quote Share this post Link to post Share on other sites
riggerquo 0 #3 July 24, 2004 When I called FXC last month they told me the battery was proprietary. They also told me that the minimum order for batteries from FXC directly was $100. Since I needed only one, I was able to purchase just one from Para-Gear. Quote Share this post Link to post Share on other sites
pchapman 280 #4 January 12, 2010 Proprietary? Hah! (Yes this is an old thread.) I just took apart an old Astra battery pack. Under the plastic wrap it is just 3 Duracell 2/3A lithium batteries nicely soldered together with custom terminals at the end of the pack. Those 2/3A = "two thirds the size of an A battery" units are also known as CR123 camera batteries. The 3V are in series so the Astra works on a nominal 9V. Soldering batteries together reliably isn't trivial so I wouldn't start buying the individual Duracell batteries locally. But FXC could have made a battery holder instead of insisting on buying packs from them. Not that it matters much, nobody really uses Astras, their adverts were hokey, they never updated their web page, and it sounds like their code was extremely simplistic. Quote Share this post Link to post Share on other sites
