freeasabird 0 #1 July 15, 2004 Looking at purchasing a used rig with a '98 javelin j4 container. Current owner says bridle between right flap and BOC pouch is not protected. However, it does have riser tuck tabs. Can a modification be done to the jav to protect the bridle? If so, anyone have an idea on cost for this? I just want to be sure of the rig I purchase so that I can have confidence while experimenting with freeflying. (PS: I already did a search and could not find specific info I was looking for.)----- Quote Share this post Link to post Share on other sites
PhreeZone 20 #2 July 15, 2004 Sunpath has a Mod for that that they can install, or your local rigger can whip something up. Its not hard at all to do. Sunpath wants $35 at the factory.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
Chrisky 2 #3 July 15, 2004 I used to have that exact setup you mention. Basically, all a rigger will have to do is sew a strip of cordura along the right side of the bottom flap, so it forms a tight fitting pocket from under the right flap to opposed to the BOC. Just route the bridle in there. Not sure whether this can be done by any rigger though (or if it has to be a Master rigger). Edit: Damn, got beat to it!!The mind is like a parachute - it only works once it's open. From the edge you just see more. ... Not every Swooper hooks & not every Hooker swoops ... Quote Share this post Link to post Share on other sites
Squeak 17 #4 July 15, 2004 It's no biggy without it. mines a '93 J1 just make sure the velcro is in good orderYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
mjosparky 4 #5 July 15, 2004 Try looking here. http://www.sunpath.com/ SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
betzilla 56 #6 July 15, 2004 Our loft charges $60 to install a bridle cover on a Javelin. Quote Share this post Link to post Share on other sites
freeasabird 0 #7 July 15, 2004 $35 ain't bad at all. Thanks all for the help! Quote Share this post Link to post Share on other sites
bch7773 0 #8 July 17, 2004 my 93 jav is just like that, and my rigger said he would charge $30 to sew the flap on. but he also said my boc pouch was too far away from where the flap would be, so he would have to move it closer, costing additional $$$. just a heads up in case sunpath tells you the same thing. MB 3528, RB 1182 Quote Share this post Link to post Share on other sites
dbattman 0 #9 July 19, 2004 Those models of the Javelin do have about 2.5 inches of exposed bridal running from the flap to the BOC. You can also consider velcro to hold the exposed bridal to the container. If you're still concerned about it, have the bridal cover installed as well. The velcro will hold tight with the bridal cover for additonal cosmetics/protection. I have one of these myself. An additonal concerm when freeflying is having a worn out BOC pouch that allows the pilot chute to be pushed out by the wind hitting it in sit fly. But of course, seek qualified rigging advice, preferably one with heavy freefly experience and exposure to the related concerns. Quote Share this post Link to post Share on other sites
riggerrob 644 #10 July 19, 2004 An additonal concerm when freeflying is having a worn out BOC pouch that allows the pilot chute to be pushed out by the wind hitting it in sit fly. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Sagging, wrinkled, old BOCs are fashion faux pas in any style of skydiving. Things just go wrong faster when sit-flying. Quote Share this post Link to post Share on other sites
