wmw999 2,595 #1 April 4, 2011 We don't have enough threads about landing patterns Instead of rehashing those, I thought we could identify the factors, and work from there instead. There are several things that used to be "common knowledge" that aren't so common any more; exit order and separation come to mind. Maybe we need to analyze and weight the considerations involved in landing patterns (note: I'm NOT an expert in landing patterns -- I'm from that past when all canopies were big and slow). What are the things that impact landing patterns? (no order here, just what I can think of). In the long run, these ought to be weighted, and then the ones that only apply to some dz's should be identified, so they can be eliminated from the dz's that don't have them. We can also include in the long run which ones are most heavily correlated with incidents (no, we don't have much more than gut feel and the 10 or so fatalities here, but there are some pretty educated guts). But for now, let's just list factors. I'm not including personality factors right now (e.g. "current poor landing discipline"). Please feel free to add, or to call me an idiot (within the personal-attack rules of dz.com, of course ). Number of jumpers in the air at a time (usually a factor of A/C size) Different loads or groups integrating Different landing areas for high-performance landings Wide mix of canopies Active student operation (i.e. lots of video & instructors) Changeable winds Small landing area Poor or few outs Long skinny landing area Poor ground visual cues (i.e. the windsock sucks) Need to coordinate with air traffic Percentage of regulars vs. visitors Transportation back from outs Thoughts? Wendy P.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
NWFlyer 2 #2 April 4, 2011 A couple more: 1) Number of aircraft flying. I separate this from number of jumpers because the number of aircraft flying could have a different impact than just the number of jumpers (could impact jump runs/spots, or if the planes are flying close enough together, the higher-loaded canopies from Airplane #2 could find themselves in the pattern with the lighter-loaded canopies from Airplane #1) 2) Number of students in the pattern. It's a sub-factor of your "active student operation" piece, but the reason I think it's a factor (though it may be what you call a "personality" factor) is the "pattern myopia" that's common among students; as much as we teach them and work with them to look before they turn and scan throughout the pattern, the reality is that students very often get into that singular focus on checkpoints and turn altitudes and successfully completing their own pattern, to the exclusion of all other visual "information" around them."There is only one basic human right, the right to do as you damn well please. And with it comes the only basic human duty, the duty to take the consequences." -P.J. O'Rourke Quote Share this post Link to post Share on other sites
shropshire 0 #3 April 4, 2011 Wind Speed, Direction & turbulence (proximity to buildings, trees etc) Distance from Spectator bleachers!!! (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
DocPop 1 #4 April 4, 2011 Wide mix of canopies and wing-loadings. This might be of significance when students are out first and are in the pattern when the video guy who was last out on a Velo loaded @ 2.5 has caught up with them and simply can't out-float a Navigator loaded @ 0.8"The ground does not care who you are. It will always be tougher than the human behind the controls." ~ CanuckInUSA Quote Share this post Link to post Share on other sites
Muffie 0 #5 April 4, 2011 I would split the active student operation category into: Active tandem operation Active SL/AFF/etc. operation Or just add active tandem operation as another factor if it wasn't supposed to be part of the student operation category. Quote Share this post Link to post Share on other sites
GLIDEANGLE 1 #6 April 4, 2011 QuoteLong skinny landing area I think what you are implying is the very real issue of the interplay of the wind direction and a long skinny LZ. If the long axis of the LZ is roughly parallel to the wind line... easy stuff for students and low timers. However, if the long axis of the LZ is across the wind line (roughly perpendicular), the students and low timers are far more likely to land someplace other than the LZ... that may be no problem, or may be a serious problem. Of course, all jumpers are affected by this, but the students and low timers tend to have the most trouble.The choices we make have consequences, for us & for others! Quote Share this post Link to post Share on other sites
GLIDEANGLE 1 #7 April 4, 2011 I would add "Local Rules". By that I mean rules like: == "First jumper down sets the pattern", or == "Pattern is right hand or left hand depending on wind direction." == "There are both Right hand and Left hand patterns separated by an imaginary line down the center of the LZ."The choices we make have consequences, for us & for others! Quote Share this post Link to post Share on other sites
wmw999 2,595 #8 April 5, 2011 I'm thinking that if we consider things besides local rules, it might be easier to come up with a consistent set of rules that don't depend so much on local knowledge and folklore. Wendy P.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
BrianM 1 #9 April 5, 2011 Different opening altitudes Different freefall speed/duration (freefly vs RW vs wingsuits) Exit order Time between exits (not distance - time!) These can all tie in together. I've been last out on wingsuit jumps, with a looong delay after the last tandem, had a long freefall, opened fairly high, spotted the tandems a long ways below me - and found myself overtaking the tandems in the pattern."It's amazing what you can learn while you're not talking." - Skydivesg Quote Share this post Link to post Share on other sites
