phoenixlpr 0 #1 June 20, 2004 Hi, Im jumping with a Maverick. My exit weight is about 80-84kg. It has a constant slite left turn. Ive check the breaklines , they are not twisted. Can it be fixed? Quote Share this post Link to post Share on other sites
nitrochute 2 #2 June 20, 2004 it depends. if the turn is the result of material bias,then no it cant be .check the rest of the lines,left side against right side.should be within1/4'' or so .a line that is just 1/8''out side to side can actually induce a turn. Quote Share this post Link to post Share on other sites
phoenixlpr 0 #3 June 20, 2004 yeah, I can check the lime trim. Quote Share this post Link to post Share on other sites
alan 1 #4 June 20, 2004 Also look into the nose openings on each cell and check the ribs for tears between the crossports.alan Quote Share this post Link to post Share on other sites
phoenixlpr 0 #5 June 21, 2004 The canopy is in really good condition and low numbers of jump. But that beast is turning :(. Quote Share this post Link to post Share on other sites
parachutist 2 #6 June 21, 2004 QuoteThe canopy is in really good condition and low numbers of jump. But that beast is turning :(. Call the manufacturer and let them know what's going on. There is a good possibility FCI can correct the turn for you: http://www.flightconcepts.com/contactus.html Chris Quote Share this post Link to post Share on other sites
riggerrob 644 #7 June 21, 2004 I would start with a full inspection (outside, inside and line trim). Secondly, try retying one steering toggle a few centimeters higher. Quote Share this post Link to post Share on other sites
