Sparky
Sparky
mr2mk1g 10
I found a page the other day saying that the new pd 99 was under tso C23-d as well @ 198mph but that appears to have dissapeard now.
Are all new PD reserves rated to 198mph?
bmcd308 0
>>We dropped the PR-99 through PR-253 at more than 300 pounds, going at least 180 knots. The canopy is certified for use up to 254 pounds at up to 150knots. <<
So PDRs are rated to 254 lbs at 150 knots. This means the minimum drop test weight and speed were 254 lbs x 1.2 = 305 lbs and 150 kts x 1.2 = 180 knots. So PD placards their reserves at the max weight and speed allowable under TSO C23d given the drop tests they performed.
One down two to go.
Brent
www.jumpelvis.com
QuoteSo PDRs are rated to 254 lbs at 150 knots. This means the minimum drop test weight and speed were 254 lbs x 1.2 = 305 lbs and 150 kts x 1.2 = 180 knots. So PD placards their reserves at the max weight and speed allowable under TSO C23d given the drop tests they performed.
I'm going to point out for the novice types that may be reading this, that when selecting a reserve size for yourself, reguardles of what the Maximun TSO rating the canopy has recieved, WINGLOADING STILL APPLIES!
After the Raven-M Bulletin you wouldn't believe the number of idiots I had come to me to buy PDR's and then tell me they wanted one 2 or 3 sizes smaller than the Raven they were replacing because "look, it says right here on the lable, rated to 254lbs."
bmcd308 0
My Wings manual says the h/c is rated to 254 lbs at 150 knots.
For the Jav, are you sure that is the rated weight and speed, or is that the weight and speed at which it was drop tested? The only reason I ask is that 300 lbs is about 254 lbs x 1.2 and 198mph is something close to 180 knots (really 175) x 1.2.
www.jumpelvis.com
Hooknswoop 19
QuoteFor the Jav, are you sure that is the rated weight and speed, or is that the weight and speed at which it was drop tested?
It is the actual TSO weight and was drop tested at higher weights.
Diablopilot- You are absolutely right and make a point worth repeating. TSO weight is not necessarily a safe weight to actually load the canopy with.
An older, worn reserve may not pass drop tests at the original drop test weight.
Derek
bmcd308 0
Interesting. I would think that Javelin would make some hay out of this in their marketing, especially since the Sunrise web site implies that the Wings is rated to higher weights and speeds than other h/c designs.
Everyone should listen to Diablopilot and Derek - in this thread, I am seeking info on the proven structural strength of the designs, not on whether anyone in particular could survive landing it.
Brent
www.jumpelvis.com
Chuck
bmcd308 0
QuoteI received a response from PD.
One down two to go.
Brent
I just found this on the JumpShack website regarding the AngelFire 196:
>>This 7 Cell F-111 Rectangular Planform Reserve is Certified under FAA TSO C23d. It has been tested structurally to 300 lbs at 207MPH. We recommend a Max wing loading of 1.2 to 1.<<
So the test was at 300 lbs divided by 1.2 means max TSO weight of 250 lbs. 207 MPH is about 183 knots divided by 1.2 is about 152 knots. So probably could be placarded for 250 lbs at 150 knots. A 1.2 WL implies 235 lbs. So does the label on this reserve say max operating weight 235 lbs. at 150 knots? Anyone have one around?
www.jumpelvis.com
bmcd308 0
One down two to go.
Brent
I received a response from Aerodyne. It said that all Smart reserves were tested at 150 knots, which would imply a max TSO'ed speed of 125 knots, which is 142 mph.
www.jumpelvis.com
Hooknswoop 19
QuoteI received a response from Aerodyne. It said that all Smart reserves were tested at 150 knots, which would imply a max TSO'ed speed of 125 knots, which is 142 mph.
Under Tso C23D, the minimum TSO airspeed is 150 kts. So if they said it was tested to 150 kts, they meant TSO'd to 150 and tested at 180.
There are 3 weights and speeds that can be listed.
1) tested to weight/speed
2) TSO'd weight/speed
3) Recommended max weight/speed
Derek
QuoteQuoteI received a response from Aerodyne. It said that all Smart reserves were tested at 150 knots, which would imply a max TSO'ed speed of 125 knots, which is 142 mph.
Derek
Derek is correct on this. But there are only 2 that skydivers are interested in.
Max certified weight/speed (TSO'd) This the max the canopy is designed to take on opening.
Recommended max exit weight. This is the max that the jumpers ankles can take on landing.
You should never fly a reserve smaller than you I.Q.
Sparky
QuoteYou should never fly a reserve smaller than you I.Q.
Whooo hooo, now they just need to come out with a 75 sq ft reserve!
Oh yeah, got your message about the rings... thanks.
How is this confirmed?
If the drop test is done from an airplane, say at 300 ft above the ground, then the "path" of the drop is longer than 300 ft vertical distance.
Is there any limitation on this 300 ft requirement? Flying fast would certainly be the obvious way to get a positive result.
