betzilla 56
QuoteDid you see the article or are you repeating what someone told you? If you saw the article, what issue? I am not saying it couldn't happen, but I think it is unlikely someone would close a reserve with a 4 foot molar strap still in place.
Nope, it's true. I saw the article too (but it was in 98 or after, I think -- after I started jumping). The rigger in question had previously jumped at a DZ I used to jump at (I never met him), so it struck close to home for me. Now that I do reserves, I actually say "molar strap out" when I remove it, just for my own peace of mind.
skydiverek 63
I saw that article. It was not even an article, but a picture of the reserve and 5-10 lines of commentary text below it. The picture was in the upper portion of the right-hand-side page - I have a good "photographic" memory
Of course there is shock value to this thread, but there is more important reason why I posted it. Some jumpres are convinced that a good reserve is a "sure" thing, that it cannot malfunction and will always work. Some of them do intentional cutaways, without a 3rd parachute, when their reserve is due for a repack. I think this is nuts, because serious rigging errors happen on reserves too. This thread should help them understand that the reserve is only to be used when a situation requires it, since it is NOT a sure thing. 99.99%, but not 100%.
skydiverek 63
From Hooknswoop:
"I know people that cutaway and deploy their reserves at re-pack time. NOT RECOMMENDED for a number of reasons. A friend of mine watched someone go in with a reserve bag lock after cutting away a perfectly good canopy (he was kown for doing this)."
Source: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=367542#367542
FrogNog 1
QuoteHere is an addition to my last post saying that reserves can malfunction (so you should always have a 2nd reserve when you do an intentional cutaway).
From Hooknswoop:
"I know people that cutaway and deploy their reserves at re-pack time. NOT RECOMMENDED for a number of reasons. A friend of mine watched someone go in with a reserve bag lock after cutting away a perfectly good canopy (he was known for doing this)."
To be more specific about that quote, it's about cutting away and deploying their reserves in the air at re-pack time.
Cutting away and deploying the reserve on the ground isn't as dangerous, and I would think it's recommended for various benefits.
Pull.
QuoteQuoteI remember a picture in Skydiving magazine in 1996 or 1997 showing a reserve that was opened on the ground for a repack and was found with a molar strap wrapped around it. The jumper had made over 100 jumps with such a setup, having basically no reserve, and obviously not knowing about it
I would tend to agree with RiggerRob and Hookitt, stirring the pot for shock valve.
Sparky
He is not making it up it was published in Skydiving Magazine. I thought Rigger Bill in Z-hill (back in 1998?) was the rigger that FOUND it not packed it.
I personally know the person that this happened to.
Judy
Chuck
QuoteThat's one reason, I don't use a molar-strap. One less thing to have to use.
BINGO!
riggerrob 644
The more times you use a tool during a pack job, the less likely you are to forget it and the easier it is to count your tools at the end of the job.
Chuck
skycat 0
Lindsey 0
Peace~
Lindsey
Sparky
A conservative is just a liberal who's been mugged. A liberal is just a conservative who's been to jail
sunshine 2
___________________________________________
meow
I get a Mike hug! I get a Mike hug!
Chuck
To answer Sunshine, it really isn't all that hard at all the way I learned. You just need to use your legs and knees a lot to keep the pack job from turning into a big mess. It was challenging at first to learn but now I don't have any problems with it at all since I am just used to it.
Sting: "Be yourself no matter what they say."
Chuck
If your being tight lipped why? What does shock value have to do with any thing? Shocking can be very educational.
If you have come across something and you have decided not to talk about it because it' nothing more than "shock value" then that's BS.
What about the new rigger who reads this post and learns something that he or she might other wise have missed.
What if you have info that could prevent a fatality? If you decide not to talk about something you have found then IMO that is trully shocking
Sparky
