jkwon 0 #1 April 6, 2004 I figure the main difference is one is rated to 550 lbs and the other is rated to 825lbs...This leads me to believe one is thicker than the other. But how much force does someone who weighs 190lbs exert on his lines?? Am I safe buying 550lb lines?? --joe--joe HISPA #69 The Best Band in the WORLD!!! The new full length album "See What You Can Find" Quote Share this post Link to post Share on other sites
skygod7777 0 #3 April 6, 2004 QuoteThis leads me to believe one is thicker than the other. your thinking is correct. QuoteBut how much force does someone who weighs 190lbs exert on his lines?? i'm not sure QuoteAm I safe buying 550lb lines?? yes, my buddy jumps a stilleto with 550, and he's about 225 or 230 out the door. the only thing with the 550 is it goes out of trim faster than the 825. that is the downside to it. later Quote Share this post Link to post Share on other sites
KevinMcGuire 0 #4 April 6, 2004 550 also wears out much faster than 825. It is even more pronounced if you land in a dirt landing area Quote Share this post Link to post Share on other sites
headoverheels 334 #5 April 6, 2004 Quotethe only thing with the 550 is it goes out of trim faster than the 825. That was my belief, and maybe still is, but Brian Germain told me that the opposite is true. I still prefer the fatter lines. I wouldn't hesitate to buy a used canopy with either type, but would probably buy 825 for a new canopy or new line set. Quote Share this post Link to post Share on other sites
skygod7777 0 #6 April 6, 2004 QuoteThat was my belief, and maybe still is, but Brian Germain told me that the opposite is true. I still prefer the fatter lines. I wouldn't hesitate to buy a used canopy with either type, but would probably buy 825 for a new canopy or new line set. if this is the case, i'm sure brian will say something on here. he posts on here. the guy who i said above (220 out the door) had to have his lines replaced at about 400 or 500 jumps with the 550, and i've seen the 825 go 800 or 900 + later Quote Share this post Link to post Share on other sites
cruzlite 0 #7 April 6, 2004 300 jumps with dacron (550) 15 with spectra(850) I don't like the way the spectra stows (seems like a limp invitation to a half hitch)... Don't like the small rubber bands... Seriously considering dacron for next canopy... D Quote Share this post Link to post Share on other sites
grega 0 #8 April 6, 2004 it seems a strange question to me but did you consider you actually have about 40 lines that's 22000 lbs at 550 lines and 33000 lbs at 825 lbs. And i think human body can't survive forces that are even less than 22000 lbs. So yes either lines are strong enough, i think "George just lucky i guess!" Quote Share this post Link to post Share on other sites
SkydiveMO 0 #9 April 6, 2004 QuoteQuotethe only thing with the 550 is it goes out of trim faster than the 825. That was my belief, and maybe still is, but Brian Germain told me that the opposite is true. That’s not what I want to hear . I just ordered a new canopy with 825lb microline with the hope it would wear better then the 550lb microline. Does anyone know if 825lb microline causes significantly greater parasite drag compared to 550lb microline? Quote Share this post Link to post Share on other sites
grega 0 #10 April 6, 2004 huh it sure does. i don't know exatly how thick 550 lbs lines are but let's say they are 3mm in diameter and 825 are 4mm in diameter 826 lbs lines are about 1 mm wider than 550 lbs lines. you have 40 lines, that are long 290 cm in average A lines probably around 270cm and D lines about 310cm (i don't know, i'm guessing according to my cobalt 120) that's 4mm*40*290= 46400 square mm with 550 lbs you'd get 3mm*40*290=34800 square mm That's 33% more drag that you get from lines. if 825 lines are only 0.5 mm thicker than 550 (which definitely are) than it's only 16.7% more drag. But we're talking only line drag not whole drag. You have a body that creates a lot more drag than the lines. just wear tight suits, and you'll swoop the same as in freefly suit with 550 lb lines "George just lucky i guess!" Quote Share this post Link to post Share on other sites
jkwon 0 #11 April 6, 2004 I didn't know I was opening up such a big discussion here. I would have to say that I didn't even think about line trim when I was making this decision. Does anyone know the true facts behind trim and which one goes out of trim faster? Sounds like some people believe the 550 goes out faster than the 825 and vice versa? --joe--joe HISPA #69 The Best Band in the WORLD!!! The new full length album "See What You Can Find" Quote Share this post Link to post Share on other sites
masterrig 1 #12 April 6, 2004 Try giving PD, Precision or Icarus a call or an e-mail. I'll bet they will be able to tell you what you want to know. Chuck Quote Share this post Link to post Share on other sites
bch7773 0 #13 April 6, 2004 and if anyone does call them up, post what they say on here... i'm kinda curious now to see the "official" answer MB 3528, RB 1182 Quote Share this post Link to post Share on other sites
SkydiveMO 0 #14 April 6, 2004 QuoteBut we're talking only line drag not whole drag. You have a body that creates a lot more drag than the lines. just wear tight suits, and you'll swoop the same as in freefly suit with 550 lb lines Which leads me back to the question is the difference in line drag of 550 vs. 825 significant? I was wondering if the drag from everything else (slider, pilot-chute, jumpers body, wing itself, etc.) so great that it makes the difference between 550 and 825lb microline even noticeable? Quote Share this post Link to post Share on other sites
mjosparky 4 #15 April 6, 2004 QuoteWhich leads me back to the question is the difference in line drag of 550 vs. 825 significant? I was wondering if the drag from everything else (slider, pilot-chute, jumpers body, wing itself, etc.) so great that it makes the difference between 550 and 825lb microline even noticeable? The 825 will create more drag than the 550 but you don't have access to the equipment that can measure the difference. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
SkydiveMO 0 #16 April 6, 2004 QuoteThe 825 will create more drag than the 550 but you don't have access to the equipment that can measure the difference. Sparky I do have access to the equipment needed to measure it however going through all the trouble to design the experiment and controls to test this would go against my lazy nature. I was hoping for the easy answer, like has anyone had 825 microline on their canopy then had it relined to 550 microline and said “Wow! That made one heck of a difference!” http://www.pcprg.com Quote Share this post Link to post Share on other sites
mjosparky 4 #17 April 6, 2004 Quotelike has anyone had 825 microline on their canopy then had it relined to 550 microline and said “Wow! That made one heck of a difference!” If you have access to the equipment and have tested with it in the past, you already know the answer. Right? SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
darkwing 5 #18 April 6, 2004 the quick answer for cylinder drag is that it is proportional to the presented area. Assuming the cross-sectional area of the line scales with its rated strength we determine that the 825 has 22% greater diameter than the 550 (if you care-- Sqrt(825/550)=1.22). So, for lines of the same length, the 825 will have 22% more frontal area, hence 22% more drag. I agree though that it is small potatoes compared to all the other drag factors, and isn't worth worrying about unless you are greased up, bare naked, have a disposable pilot chute and d-bag, and are shooting for a record. -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
SkydiveMO 0 #19 April 7, 2004 QuoteI agree though that it is small potatoes compared to all the other drag factors, and isn't worth worrying about unless you are greased up, bare naked, have a disposable pilot chute and d-bag, and are shooting for a record. That's what I was wondering! Sure I could sit down and calculate everything out but in the end what I wanted to know is under canopy could I feel the difference? QuoteIf you have access to the equipment and have tested with it in the past, you already know the answer. Right? It’s funny, you can spend all day calculating how a parachute should open and fly then you throw it out of an airplane and it does something completely different. I let the professor handle the calculations I just like to push stuff out of airplanes and see if they open Quote Share this post Link to post Share on other sites
darkwing 5 #20 April 7, 2004 QuoteIt’s funny, you can spend all day calculating how a parachute should open and fly then you throw it out of an airplane and it does something completely different. I let the professor handle the calculations I just like to push stuff out of airplanes and see if they open I agree, it is just that very often people don't believe you without the numbers. Numbers are great, but until you fly it, the simulations won't really answer all of the questions. -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
jkwon 0 #21 April 7, 2004 I had another experienced jumper tell me that the 825 lines wear faster than the 550 lines. ??? I'm guessing it has something to to with total surface area actually contacting the grommets of the slider. That has to be the only explanation. --smiley--joe HISPA #69 The Best Band in the WORLD!!! The new full length album "See What You Can Find" Quote Share this post Link to post Share on other sites
skymoo 0 #22 January 18, 2007 Rusty, very nice guy at PD, confirms that the 825lb microline lasts longer than the 550lb microline. "they are thinner and have less weave, any nick or scratch percentagewise will wear out the line more" now, the advantage is confirmed to be less drag, but in his words "only the very advanced canopy pilots" have use for this slight difference. I'm sticking to 825s Yup, it took three years to answer this http://www.childrenofthesky.com Freefly! Quote Share this post Link to post Share on other sites
everymansaved 0 #23 January 19, 2007 If trim is a big conern, go with Vectran (assuming it's offered on the canopy you want). You have to replace it more often, but it never loses trim. EFS Sean LRGod made firefighters so paramedics would have heroes...and someone can put out the trailer fires. Quote Share this post Link to post Share on other sites
Tonto 1 #24 January 19, 2007 Quote has anyone had 825 microline on their canopy then had it relined to 550 microline and said “Wow! That made one heck of a difference!” No, but I went from 550 to 825 on a reline, and thought "Wow! That made one heck of a difference!" I noticed an increase in performance. Amazing what being it trim will do to a canopy. tIt's the year of the Pig. Quote Share this post Link to post Share on other sites
RMURRAY 1 #25 January 19, 2007 QuoteIf trim is a big conern, go with Vectran (assuming it's offered on the canopy you want). You have to replace it more often, but it never loses trim. EFS Sean LR exactly. I would not reline any canopy with spectra these days... rm Quote Share this post Link to post Share on other sites
