sangiro 26 #1 April 11, 2003 Greetings! I know you've all probably been bugged by those annoying Proxy Error messages. I'm obviously aware of that and will be taking some steps to see if I can improve the performance again. At this time we're simply using more CPU power than my Dual 1.2 GHz processors can deliver. I've attached a graphic (for the geeks!) A load average of 2 means the 2 processors are both running at 100% capacity. As you can see we average at 1,93 and there are sustained periods where it stays between 4 and 6! So, I need to do a few things to see if we can lighten the load. In the near future we will: * move to a new server with 15k scsi drives * upgrade to MySQL 4 (query caching in MySQL 4 greatly improves performance) * upgrade to ReiserFS file system (a high performance file system) This will require one to two hours of downtime to move the server over. As always I'll post a warning so the post-whores in our midst don't have too much angst. After this is done we'll monitor what happens and take further steps if needed. A few other notes: * this is simply a product of high traffic. Lots of server requests and processes * high bandwidth (data transfer) usage is not the cause of these errors. While not causing the performance issues, it costs money. * there's a lot of storage space left, no need to delete emails or PMs, although it's good discipline to clean up a bit anyway. Thanks for your patience. Peace out! Safe swoops Sangiro Share this post Link to post Share on other sites
