newbie4ever 0 #1 August 10, 2006 i can't get into specifics...but i'm needing to circumvent some stuff on an "a". was wondering how an aluminum ladder would react up against an "a". and to avoid the obvious "why not use a wooden ladder if you're afraid argument" I need to say that in this case it has to be a aluminum ladder (a motified aluminum ladder, can't get into specifics, i promised the guy.... you know the story) anyway all information would be appreciated. thank you. Share this post Link to post Share on other sites
leroydb 0 #2 August 10, 2006 Send via PM: Whats the FCC Id or other identification? Easy enough to figure out what it is used for.Leroy ..I knew I was an unwanted baby when I saw my bath toys were a toaster and a radio... Share this post Link to post Share on other sites
base736 0 #5 August 11, 2006 An aluminum ladder will do more-or-less exactly what a steel or other metal ladder will do... Which is to say, if it touches the antenna it will "be one" with the antenna. Share this post Link to post Share on other sites
crwper 7 #6 August 11, 2006 Is the structure itself live? I assume you're asking because it is, but hey, you know what they say about assumptions. Michael Share this post Link to post Share on other sites
newbie4ever 0 #7 August 11, 2006 it's a fm/tv from what i've researched. does that make a difference? i've been told that a "AM" IS BAD NEWS for this situation. more innput would be greatly appreciated. thank you. Share this post Link to post Share on other sites
crwper 7 #8 August 11, 2006 With FM antennas the structure itself is usually not live. If there's a lot of hardware hanging off of it (dishes and such), then that stuff is probably doing the transmitting/receiving. The "antenna" is really just a tower. With AM antennas the structure is the antenna, so it's usually live. There will be no hardware hanging off the antenna, and the guy wires and base of the antenna are usually insulated from the ground. If the structure is not live, it shouldn't matter what kind of ladder you use. Michael P.S. Search the forum for "AM FM" and you'll turn up a lot more information. Share this post Link to post Share on other sites
460 0 #9 August 11, 2006 I'm wondering how a ladder might react against an "a" Is this some sort of bad chemistry class?Looks like a death sandwich without the bread - Steve Deadman Morrell, BASE 174 Share this post Link to post Share on other sites
base736 0 #10 August 11, 2006 QuoteAn aluminum ladder will do more-or-less exactly what a steel or other metal ladder will do... Which is to say, if it touches the antenna it will "be one" with the antenna. My bad. I had assumed, since you were asking, that the antenna was AM. As crwper pointed out, the structure of an FM antenna is harmless. An aluminum ladder touching it will therefore be just as harmless. Share this post Link to post Share on other sites
newbie4ever 0 #11 August 13, 2006 thanks. still hane not finished the ladder alterations but all this info. is good. i might try the rope and pvc pipe but the ladder in this case would be easier. thanks again for all the input and anymore would be good. Share this post Link to post Share on other sites
leroydb 0 #12 August 14, 2006 rope or 1" tubular nylon... that would take up less space and might be lighterLeroy ..I knew I was an unwanted baby when I saw my bath toys were a toaster and a radio... Share this post Link to post Share on other sites
newbie4ever 0 #13 August 14, 2006 i think i'm going to go there with both ladder and the rope thing leroy mentioned. Share this post Link to post Share on other sites
leroydb 0 #14 August 14, 2006 note that you dont have to have PVC on every rung, just every few or more. U might also want to secure each rung by drilling a hole and trying it off somehow. I wouldn't want you to slipp or anything. also, please have some GC to remove the ladder once you are on the A so its one less thing to worry about once you are exfilling the area... my 2 centsLeroy ..I knew I was an unwanted baby when I saw my bath toys were a toaster and a radio... Share this post Link to post Share on other sites
newbie4ever 0 #15 August 14, 2006 thanks leroy good advice!!! Share this post Link to post Share on other sites
HydroGuy 0 #16 August 14, 2006 Somewhere I've heard nylon can conduct electricity...is this only at extremely high voltages?Get in - Get off - Get away....repeat as neccessary Share this post Link to post Share on other sites
460 0 #17 August 14, 2006 above about 600V @ 60Hz I have heard but not confirmed.Looks like a death sandwich without the bread - Steve Deadman Morrell, BASE 174 Share this post Link to post Share on other sites
