n_pertuset 0 #1 January 7, 2006 I just started skydiving ... and i want to develop my skills to help me for when I start BASE. I realize there are a lot of necessary pre-requisites before starting BASE (mainly skydiving experience), and i'm not trying to rush anything, i'm just trying to "well-prepare" myself. I'm looking into buying my first skydiving rig, and I was told by a local BASE jumper to get a lot of practice on large, 7 cell canopies if I want to get into BASE. I am 5'7", and weigh 145 lbs. I'm wondering what size main would best help me to learn skydiving, and help develop skills necessary for BASE. I’m also wondering if I should start out with this canopy and what not. Thanks in advance.Nathan Share this post Link to post Share on other sites
DexterBase 1 #2 January 7, 2006 Fill out some more information in your profile, include your body weight, and we can help you a little more. Share this post Link to post Share on other sites
Tenshi 0 #3 January 7, 2006 Quoteinclude your body weight My magic eightball says 145 pounds. Share this post Link to post Share on other sites
TomAiello 26 #4 January 7, 2006 You'll want a canopy in the 240ish range. You might consider something slightly smaller for skydiving (because in strong winds you might not be able to get back to the DZ), but for BASE practice, sizing right on what you'd use for BASE is best. Your best bet is to find a local BASE jumper and get them to coach you through your skydiving with BASE in mind. Definately work on accuracy (including cross-wind and down-wind accuracy, if your DZO/S&TA are ok with that). Also practice some riser flares (again, check with your skydiving folks to make sure they're ok with it). Try to do some CRW. If you can convince some locals to do CRW on BASE canopies, that's a really good learning experience as far as the canopy's performance envelope. But even just "normal" CRW is really good experience, too. CRW jumpers are the only skydivers who are really used to flying in close proximity to obstacles (which is a mandatory survival skill for a BASE jumper). Also practice tracking. Tracking well is a major plus for a BASE jumper. If you get a chance, trying out a tracking suit like the Phoenix Fly suit is both fun and educational. Depending on your skydiving experience level, you may be able to throw on a wingsuit as well, but if you're just skydiving for BASE, that's probably not going to be as easy, due to low skydive jump numbers. Be aware that the Prodigy is a very BASE friendly suit (Phoenix Fly claims to have developed it as a beginner suit, but my honest opinion is that they were really trying to build the world's best BASE tracking suit). The S-Fly Access should also be good for BASE. (Basically, you want to be able to get to your risers for heading correction without spending the half second to pull the cutaway cables.) To repeat: Your best bet is to find an experienced local BASE jumper who can guide you through the skydiving progression. This will also set you up with a mentor for your BASE career. Hope that helps.-- Tom Aiello Tom@SnakeRiverBASE.com SnakeRiverBASE.com Share this post Link to post Share on other sites
n_pertuset 0 #5 January 8, 2006 Thanks Tom. That helps a lot! Time to get started ....Nathan Share this post Link to post Share on other sites
