87SupraT 0 #1 November 2, 2005 How far does one usually fall before being under canopy in a PCA jump? Watching some videos, it seems alot of people are under canopy by around 50 feet at the most. My perception of distance could be wrong since it is on video and not in real life, though. Thanks. Dale~Dale Share this post Link to post Share on other sites
DexterBase 1 #2 November 2, 2005 It' further than that but depends on the skill of the person holdig the PC. It can range from your feet being at 75 feet below the exit point on bottom skin inflation (good PCA), to no difference than freefalling (bad PCA). Share this post Link to post Share on other sites
GeordieSkydiver 0 #3 November 2, 2005 What is the trick to 'giving' a good PCA then?Lee _______________________________ In a world full of people, only some want to fly, is that not crazy? http://www.ukskydiver.co.uk Share this post Link to post Share on other sites
DexterBase 1 #4 November 2, 2005 Don't drop the PC! Use the DexterBASE approved bridle folding method and you'll never drop another PCA. Guaranteed. Share this post Link to post Share on other sites
TomAiello 26 #5 November 2, 2005 QuoteUse the DexterBASE approved bridle folding method and you'll never drop another PCA. Guaranteed. Or your altitude back?-- Tom Aiello Tom@SnakeRiverBASE.com SnakeRiverBASE.com Share this post Link to post Share on other sites
DexterBase 1 #6 November 2, 2005 Or your altitude back. Share this post Link to post Share on other sites
87SupraT 0 #7 November 2, 2005 I see, thanks for the info and the quick response. What about static-line deployment? Do you fall further or less with that? Dale~Dale Share this post Link to post Share on other sites
TomAiello 26 #8 November 3, 2005 QuoteI see, thanks for the info and the quick response. What about static-line deployment? Do you fall further or less with that? Roughly the same. In theory, static line and PCA should perform almost the same. In practice, I've seen good PCA's that seem a bit better than a static line, and plenty of bad PCA's that are much worse. The PCA just puts a human element into your static line (for better or worse).-- Tom Aiello Tom@SnakeRiverBASE.com SnakeRiverBASE.com Share this post Link to post Share on other sites
DexterBase 1 #9 November 3, 2005 Here's the hot tip: If you're going to PCA someone from a low dodgy cliff, put on a climbing harness and tie in to an anchor of some type. Or have someone hold you by your waist. If you think you're gonna get pulled off the cliff, you're a lot more likely to drop the PC. Share this post Link to post Share on other sites
87SupraT 0 #10 November 3, 2005 Quote Roughly the same. In theory, static line and PCA should perform almost the same. In practice, I've seen good PCA's that seem a bit better than a static line, and plenty of bad PCA's that are much worse. The PCA just puts a human element into your static line (for better or worse). I see, the PCA definitely adds another element that can possibly go wrong. Why do so many people still do PCA's? Is it that hard to rig up a static line? QuoteHere's the hot tip: If you're going to PCA someone from a low dodgy cliff, put on a climbing harness and tie in to an anchor of some type. Or have someone hold you by your waist. If you think you're gonna get pulled off the cliff, you're a lot more likely to drop the PC. I see, the thought of falling, makes you more susceptible to letting go early in fear of falling. Makes sense. Thanks for the info ~Dale Share this post Link to post Share on other sites
TomAiello 26 #11 November 3, 2005 QuoteI see, the PCA definitely adds another element that can possibly go wrong. It also adds another element that can go right, and perform better than a static line. QuoteWhy do so many people still do PCA's? They are extremely convenient. You can think you're going to freefall the jump up until 30 seconds before exit, and then do a PCA. Static lines take a bit more foresight.-- Tom Aiello Tom@SnakeRiverBASE.com SnakeRiverBASE.com Share this post Link to post Share on other sites
nicknitro71 0 #12 November 3, 2005 QuoteI see, the PCA definitely adds another element that can possibly go wrong. Why do so many people still do PCA's? Is it that hard to rig up a static line? No it's not but sometimes you do not have an attachment point on the object. We usually jump a S where we cannot use a S/L. By the way I do not like holding the PC strongly when PCAing. What I do is to S-fold the bridle in one hand and hold that strong then leave some slack and hold the PC in the other hand. This method has been proven very effective even when 1st time PCAers are used.Memento Audere Semper 903 Share this post Link to post Share on other sites
87SupraT 0 #13 November 3, 2005 I can see the ease/convience of doing a PCA on an object you thought of freefalling prior. I forgot about not having an attachment point for a static line on some jumps, that kind of slipped my mind. Thanks for the information guys, I appreciate it. I believe that is all...... for now Dale~Dale Share this post Link to post Share on other sites
LouYoung 0 #14 November 3, 2005 Tom, Have you seen many slider up PCA's at the bridge? Any guess on how much altitude is normal for a s/u PCA to start flying? A friend and I were talking about jumping a low-ish object near here that we always freefall, but he only had a s/u rig packed. I suggested that I PCA him and see what happens. He didn't want to go for it, though. Lou Share this post Link to post Share on other sites
DexterBase 1 #15 November 3, 2005 Is your lowish object solid? How bad would a 180 be? I've done a couple slider up PCA's Share this post Link to post Share on other sites
LouYoung 0 #16 November 3, 2005 Overhung, solid, about 250 to impact. A 180 has various implications depending on how high you are, since the object is overhung. I've seen people rollover off the object before. Lou Share this post Link to post Share on other sites
TomAiello 26 #17 November 3, 2005 QuoteHave you seen many slider up PCA's at the bridge? Any guess on how much altitude is normal for a s/u PCA to start flying? Yes, but not a whole bunch of them. In general, they happen when plans change at the exit point (or just before, as in your case) or when you want a really soft opening (I did some of these as my first jumps back from spine surgery about 6 years ago). I've never made any attempt to measure exact opening altitude on one. I'd say you are going to be open lower than a slider down freefall, so 250' sounds a bit sketchy to me. However, be aware that a slider up canopy begins decelerating you as the slider starts to descend. The slider does not need to reach the links for the deceleration to reach a point where water impact is easily survivable without injury. If your object is over water, I think you could try it out in relative safety, and form some opinions about doing it over hard ground.-- Tom Aiello Tom@SnakeRiverBASE.com SnakeRiverBASE.com Share this post Link to post Share on other sites
leroydb 0 #18 November 3, 2005 I'D GO S/U s/L FROM 400 or higher....Leroy ..I knew I was an unwanted baby when I saw my bath toys were a toaster and a radio... Share this post Link to post Share on other sites
LouYoung 0 #19 November 3, 2005 I'm pretty sure no one will actually be trying it out off this object. We were just joking around with it, but it got me to thinking about how much altitude it'd really eat up. This object is over hard ground, though the talus is relatively soft and free from anything really large. I'm curious enough now that if I find something lowish over water I might give it a shot. Lou Share this post Link to post Share on other sites
DexterBase 1 #20 November 3, 2005 I'm betting you'd be okay, but I'd be pretty reluctant to try it over dirt. Share this post Link to post Share on other sites
subterminal 0 #21 November 4, 2005 While on the pca tangent, I'm really curious if any one has experienced serious off headings on pca jumps? We used to do quite a few of them some years ago and I have personally have never seen any really bad openings, and I can't remember hearing anyone experiencing it either - apart from this one dude who tried to incorporate a gainer on a pca jump... CJ =) Share this post Link to post Share on other sites
TomAiello 26 #22 November 4, 2005 In my experience, opening heading on a PCA is much more consistent than on a freefall. I theorize that this is because the extraction point is steady, rather than moving. I have, however, seen a 180 on a PCA. A PCA is not a guarantee of an on heading opening. Nothing, so far, appears to constitute such a guarantee.-- Tom Aiello Tom@SnakeRiverBASE.com SnakeRiverBASE.com Share this post Link to post Share on other sites
gweeks 1 #23 November 4, 2005 QuoteI have, however, seen a 180 on a PCA. Did everything else about the PCA seem normal? Share this post Link to post Share on other sites
TomAiello 26 #24 November 4, 2005 QuoteQuoteI have, however, seen a 180 on a PCA. Did everything else about the PCA seem normal? Yes. It was a light tailwind from a span (which, I would have thought based on other experience, makes an on-heading more likely).-- Tom Aiello Tom@SnakeRiverBASE.com SnakeRiverBASE.com Share this post Link to post Share on other sites
Tyrion 0 #25 November 4, 2005 QuoteI have, however, seen a 180 on a PCA. A PCA is not a guarantee of an on heading opening. Nothing, so far, appears to constitute such a guarantee. I read this an was wondering if you've ever seen a bad off-heading when someone's done a rollover? Share this post Link to post Share on other sites
