Anvilbrother 0 #1 November 1, 2005 As I see it pin rigs are for WS, aerials, and terminal jumps. Velcro rigs are better for non terminal, and terminal if the velcro is in great shape? Is it adviseable to use a pin rig for a 430' A with 1 sec> delays? On a side note I am glad to see them making canopies larger. The flick 322 gives my big ass hope to jump one day. edit for thread title ~TA Postes r made from an iPad or iPhone. Spelling and gramhair mistakes guaranteed move along, Share this post Link to post Share on other sites
TomAiello 26 #2 November 1, 2005 I've split this off into it's own thread. You can search through the forums for endless opinions on pins and velcro. My opinions are not necessarily representative of the majority of BASE jumpers today, but for what it's worth, here's what I think: A pin rig on a 430' A with 1 second delay is going to be fine. The areas where pin rigs are a little weaker than velcro are generally packing and closing (it's a bit harder to close symmetrically, which really only matter when you first start, and it's possible to pack totals if you don't know what you're doing [it's pretty much impossible to pack a total on a velcro rig]). I prefer velcro rigs for beginners for those reasons. I don't really think there are many problems with velcro rigs at terminal. I wouldn't use them for wingsuit flights, but for delays of 15 or less, I think that they're going to be fine. I've tracked on my back at terminal, wearing a velcro rig (without a tuck flap) and had no real fear about doing so. I'm uncertain as to where the "velcro is bad for aerials" thing came from. I can't really see a reason why this would be the case with a properly fit and closed velcro rig (same as with a properly fit and closed pin rig). In fact, with body position changes, the pull tension on a pin rig can vary dramatically, where the pull tension on a velcro rig will stay pretty much constant regardless.-- Tom Aiello Tom@SnakeRiverBASE.com SnakeRiverBASE.com Share this post Link to post Share on other sites
Anvilbrother 0 #3 November 1, 2005 Yea I prefer the idea of a velcro rig over pin. I have helped, and done some mentoring with truckerbase, and like the idea of velcro over pin after packing and discussing things like the shrivel flap. I was just trying to put my thoughts in order. Postes r made from an iPad or iPhone. Spelling and gramhair mistakes guaranteed move along, Share this post Link to post Share on other sites
leroydb 0 #4 November 1, 2005 For all I fully see the benifits of velcro over pin rigs onlow jumps. At the same time I have only 5+/- velcro jumps. Most of my jumps are freefalls from 300ft and below using a gargoyle pin rig, so YMMV. just be confident, current, and knowledgable in the decisions you make when you jumpLeroy ..I knew I was an unwanted baby when I saw my bath toys were a toaster and a radio... Share this post Link to post Share on other sites
