PiLFy 3
Den splain that to me, Lucy... Was not some phenomena @work to cause these hard openings?
QuoteWere any other jumpers complaining of hard openings?
Either those packed by you or by someone else?
For the second jumper, he said 4 people did hop and pops on his load, and 3 of them had hard openings. His canopy was the only one I packed, and the other two were by someone else.
JohnRich 4
QuoteIn other words. Picture a column of air. The column is the vertical track the chute will follow while inflating. If it's very dry within the column? The chute won't have to compress a lot of water molecules in the air on the way down. If there's a high concentration of water molecules in that column of air? They will quickly begin to be compressed by the chute as it snivels/opens, creating more resistance.
If that were true, there would be an epidemic of hard-openings in high-humidity places like Florida and east Texas. But it ain't happening...
QuoteAs density altitude increases, a ram-air canopy pilot can expect the following:
d. higher opening forces
I read the SIM's explanation shortly after the hard openings, and I thought I had found my answer as to why they happened. But then I researched density altitude, and I realized that the conditions of that day all point towards a decrease in density altitude. The high humidity, high temperature and lower atmospheric pressure would mean lower opening forces. So I was like, "WTF, maybe I am a horrible packer."
Basically, I sum the SIM's explanation as "your parachute will open harder in the winter, than in the summer at your DZ."
PiLFy 3
billvon 3,151
HOWEVER this is a pretty minor effect. Even a very significant change* in temperature and humidity will only change density altitude by about 3000 feet, so it's as if you opened 3000 feet higher - and generally that's not a huge difference. You have to be opening pretty high to notice significant changes in opening 'hardness.'
I'd look at other factors first. Hotter temperatures may mean you're wiping your face more while packing (I know I do) and that you have less control over the pack jobs. Hotter temps may mean people are jumping without suits or with summer (fast) suits, and that leads to faster deployment speeds.
(* - in this case, 50 degrees at 10% humidity vs. 90 degrees at 100% humidity.)
>So now I'm wondering if the approaching thunderstorm is the factor I really
>need to consider.
Not that in and of itself. However, its effects on the air may have a minor effect, and its effects on jumpers may be significant as well.
Divalent 166
I understand that terminal velocity would be faster at lower air densities (whether due to real altitude or to atmospheric conditions), but shouldn't that also affect the processes involved in the canopy opening? I mean, consider two extreme cases where one is opening at terminal V at 12K on a very hot humid day vs a cold dry day at 3K. It seems to me the force of the wind per unit area should be the same in either scenario at terminal V (although terminal V would be faster at 12K). So shouldn't the force of the wind inflating the cells and expanding the canopy be the same? And although from 12K one has to lose more velocity, the force of the wind against a particular surface area of the canopy should be the same, and so shouldn't the decellerating G force be the same?
I suspect I'm overlooking/oversimplifying some step in the opening process. Anybody got a good explanation (or even a good theory) why one would expect openings to be harder at higher altitudes?
QuoteHigh temps and humidity result in high density altitudes, and high density altitudes can result in harder openings since decelerations are greater.
Oops, I forgot I always tend to read high density altitude as high density altitude, and then I start thinking in terms of air density.
You're right though, when I jumped at Colorado I noticed the faster freefall speed and canopy descent than I'm used to, but I didn't notice much of a canopy opening harder or softer.
QuoteHotter temps may mean people are jumping without suits or with summer (fast) suits, and that leads to faster deployment speeds.
That's definitely true about the second jumper I packed for as he was in shorts and long sleeves. He did tell me he tried to slow himself down before deployment, though, after being warned by the first jumper I packed for. The first jumper was in a camera suit though, so I'd assume he was actually going slower.
What are the chances these guys opened up in the updraft of a thermal?
Quote4. As density altitude increases, airspeed increases
5. As density altitude increases, a ram-air canopy pilot can expect the following:
c. a faster descent rate
I'm beginning to question that, too. If both your fall rate and your canopy descent rate increase due to the thinner air, it would seem like your canopy opening forces would be more or less equivalent.
billvon 3,151
Yes, and so it opens at the same _speed_. But if it takes 2 seconds at 3000 feet vs 2 seconds at 12,000 feet, your opening at 12,000 feet will be harder - because you started from 140mph instead of 120mph. Now take it to 30,000 feet and you have 2 seconds to slow down from 180mph - that's really going to hurt.
Not a chance.
D-10855
Houston, TX
