Trev_S 0
Have you yet covered canopy collisions, wraps and entanglements in your EP training?
Yeh. I was taught that if it's unavoidable get big (spread arms n legs).Communicate with each other (if you're on the bottom read out altitude to guy in wrap, let him know if his canopy is good etc). Figure out if some1 needs to chop, wait for OK b4 chopping if you do. Make decision whether or not to disconnect RSL.
Only other situation I can think of for disconnecting the RSL is if you're landing in water. If the canopy sinks you'll have to cutaway from it and you don't want your reserve coming out if that happens.
I can't think of any other reason??
I realize that you are in Aussie land and your country's procedures may be different for some of these things. I offer USPA recommendations as food for thought and discussion with your mentors.
..there's more though.
You didn't talk about wraps and entanglements.
Collisions:
There is another school of thought that says make yourself as small as possible with the intent to pass through the lines instead if getting tangled up in the. In fact. USPA recommends that (see USPA SIM 5-1 H). Why? One reason is that Spectra lines will cut you to the bone...not good. Like everything else, there's pros/cons with both methods. Discuss the pros/cons with your instructors as always.
Also from the SIM 6-6:
3. If a collision is imminent:
a. The jumpers should spread one arm and both legs
as wide as possible to reduce the possibility of
penetrating the suspension lines, provided the
suspension lines are made from larger diameter
Dacron©.
b. The other hand is used to protect the
reserve ripcord.
c. Canopies with small diameter suspension line,
such as Spectra or HMA, can lead to more serious
injuries during a collision than canopies using
larger diameter suspension lines made from
Dacron©.
(1) Jumpers should tuck in arms, legs and head if
the collision involves canopies with small
diameter suspension lines.
(2) Avoid hitting the suspension lines or other
jumper, if at all possible.
Sadly, it seems that USPA has done away with defining wraps and entanglements and only mentions entanglements now. Ask about what they are and the procedures that used to be recommended for each. If you have some highly experienced CrW dogs on the DZ...talk to them. They are the best to answer these types of questions.
Situations I can think of for disconnecting the RSL:
High winds on landing
Landing on a building
Landing in a tree
Landing in water
Landing in power lines
Upper jumper in an entanglement situation
Two canopies out
If you care to, you can get a hard copy or a soft copy (PDF file) and read it...it's our skydiving bible in the U.S.
http://www.uspa.org/SIM.aspx
Trev_S 0
Can you tell what lines people are using before you collide?
QuoteCan you tell what lines people are using before you collide?
And therein lies the rub....I guess USPA expects us to call time out and ask just before the crash.
NWFlyer 2
QuoteQuoteCan you tell what lines people are using before you collide?
And therein lies the rub....I guess USPA expects us to call time out and ask just before the crash.![]()
While some of the EPs may also be relevant to people not doing CRW who find themselves in a canopy collision, if you're going to quote from 6-6, you probably also want to mention that's the section on CRW. I'm not a CRW dawg, but I'd imagine one would be aware of the equipment (including line type) if you're choosing to do CRW.
hillson 0
I would just assume that everything in the air around me is microline or worse and would act accordingly...attempt to protect belly, chest, and neck (at the expense of arms and shins, i guess). Probably covers 99% of the situations.
Of course...hope to never, ever be there...
Outside of the situations you mention above, the only time I disconnect my RSL is for clear and pulls from altitude.
QuoteI'm not a CRW dawg, but I'd imagine one would be aware of the equipment (including line type) if you're choosing to do CRW.
True enough. Keep in mind we are talking for the benefit of young jumpers who typically are NOT aware of special equipment for CrW. A wrap or an entanglement is as it is regardless of the disciple being worked.
On top of that I went back to refresh my memory on it and sure enough, there is no USPA recommendation for line type.
QuoteI would just assume that everything in the air around me is microline or worse and would act accordingly...
Exactly.
RSL...clear and pull from altitude?...I don't understand that. Would you elaborate, please?
Thanks in advance.
edited to add:
Because if you had to cutaway at altitude, you'd want to wait until normal pull altitude before deploying the reserve?
QuoteQuoteI would just assume that everything in the air around me is microline or worse and would act accordingly...
Exactly.
Thanks in advance.
edited to add:
Yeah...it's in the SIM ~ Ya grap one main toggle in the left hand and chop the function...
Drag the main down to 2200' with ya so you can find it easier...let go of the toggle from the main, and then fire off plan B.
YOU SHOULD KNOW THIS STUFF!
You had a two-out.
I has a line-over a streaming spinner. I'm not strong enough to hold on so I'd ride the rock 'n roller down to 2K and fire.
hillson 0
QuoteRSL...clear and pull from altitude?...I don't understand that. Would you elaborate, please?
Thanks in advance.
edited to add:
Yeah...sort of beyond the scope of the original question but...several possible failure / malfunction modes.
1) Generally if I do a clear and pull from altitude it is with a group. Maybe some proximity flying, light end cell bump etc. Never know when a wrap / entanglement may bite you. Better be prepared...
2) But no RSL (for me) is mainly for a mal right out the door. Not talking about some spinny thing where you're in danger of passing out or, god forbid, some fucked up horseshoe etc...I take good care of my stuff but Murphy lurks, right?...but standard failure modes post-deployment where there is the possibility having enough altitude to take a bit to see if it can be fixed etc. If not...if you can ride it down to an altitude where there is a better chance of recovering your gear before cutting away.
3) The real gnarly stuff would be something higher speed like a streamer or a bag lock with enough drag to stand you up and start booking. If it is stable enough to be ridden down for a bit I'd like to chop it lower to increase chances of recovery but, more importantly, have enough altitude to slow down a bit after cutaway. I'd rather head back into freefall and then pop the reserve rather than having it blast off my back at 170mph...Plus, what if there isn't enough drag to clear the risers etc. Would like some altitude to sort that, too.
Alti would probably be somewhere between 5-7K depending on the specific situation. I wouldn't bother riding it down to 3K.
Edit: maybe I'm over thinking...but I'm assuming that with slower speed type stuff one may have the altitude to figure it out / ride it a little bit assuming it is relatively stable. Assuming, too, I'm within reasonable / makeable distance of the DZ / safe outs etc - ie: not 3 miles over the swamp. I'm new...could be wrong.
Trev_S 0
I can understand why experienced jumpers would do this but isn't it still an unnecessary risk? I would have thought getting your reserve out ASAP even if you're at 7000 for eg would be safer as it gives you tons of altitude to work out any mals your reserve may have (line twists for eg).
QuoteQuote
You are quite right Grasshopper.
No one, regardless of experience level should ever attempt to pull a stunt like that.
I can think of 5 things that 'could' go wrong and ruin your whole day...there are probably more but I got a headache today so I'll stop at 5.
You're relatively new to this site so you get a pass...for future reference ~
I'm an extremely sarcastic, grumpy old fart that 'experimented' WAY too much in the 70's, when ya see a lil' devil icon in a post of mine - it's a pretty safe bet I'm just bullshittin' again.
Heads up call on your part for smelling a rat and asking a question...you'll go far in this sport!
QuoteQuoteRSL...clear and pull from altitude?...I don't understand that. Would you elaborate, please?
Thanks in advance.
edited to add:
I really think most of what you've posted is simply because you don't have the experience to know better. Once you have determined that a parachute is un-landable, WHY would you even consider delaying your EP's? Are you SURE that your reserve will be without problem? Are you SURE that you will have an uneventful release?
Ive seen both those things and much more and I've only been doing this for 15 years.
billvon 3,151
These two statements are very worrisome. They reveal an approach of "malfunctions are straightforward; emergency procedures always take a few seconds so I'll wait a while before taking action." What if you can't find your reserve handle? What happens if your main just spins and spins for a while, then when you go to cutaway, the twists have trapped your cutaway cables? What if your reserve is harder to pull than you thought it was? What if the long spin loosened your harness and your reserve pull now just pulls your main lift web away from your chest?
(I've seen all those things happen)
If there is enough drag to stand you up you're going at freefall or slower speeds. If there's not enough drag to stand you up then you can stay on your belly and remain at freefall speeds. Both are bad options; cut away and deploy your reserve. It is never in your best interest to remain under a malfunctioning parachute.
If you do, for some reason, want to cut away and not have your reserve open, then disconnect your RSL before cutting away. If you don't have time to do that - then be glad that RSL is there to save you a few more seconds when you need them.
hillson 0
nigel99 659
QuoteIf you care to, you can get a hard copy or a soft copy (PDF file) and read it...it's our skydiving bible in the U.S.
Andy, while I like the SIM and have a copy, I think for an Aussie Student our Operational Regulations and "A license Manual" and "B license Manual" would be better reads. There are enough differences (opening heights, license requirements, cloud jumping etc) that the SIM could cause confusion.
Once he's got his B license I agree the SIM is a valuable reference tool.
Yeah...and YOU smelled out the rat I threw.
God how I was praying that nobody would actually consider doing the "ride-out".
![[:/] [:/]](/uploads/emoticons/dry.png)
QuoteQuoteIf you care to, you can get a hard copy or a soft copy (PDF file) and read it...it's our skydiving bible in the U.S.
Yep...hence, I wrote...
"I realize that you are in Aussie land and your country's procedures may be different for some of these things. I offer USPA recommendations as food for thought and discussion with your mentors. "
I didn't think of the confusion factor...I was trying to encourage reading about stuff and talking about stuff.
Thanks for the heads up on the confusion factor.
Trev_S 0
jsaxton 0
Quote[reply[
Trev_S 0
Fuck I'd love to see that hahaha
Slow down a little Trev. No need for excitement. OK? Never said that. Never implied that. See the above "exactly".
There ya' go! Simple, precise and to the point.
Yes. Personally, I can't think of any situation where that would not be applicable.
