rocketscientist 0 #1 February 8, 2004 i was curious on how to store my main for the winter..i searched other posts, and decided to leave it packed all winter and have a rigger go through it completely at the begining of the season. to get to the point i read how you should do a monthly check of the 3ring riser and webbing and to "flex the webbing" i know it sound pretty self explanitory, "as in take the webbing and flex it" but would like a little better understanding of what i should be looking for in doing this.My inner child is a mean little fucker Quote Share this post Link to post Share on other sites
riggerrob 644 #2 February 9, 2004 Pull the release cable completely off the rig and clean it with a rag. Disconnect the risers from the harness rings. Flex, bend, twist, wiggle the riser webbing - near the middle and small rings - at every angle you can think of. Also remember to flex the little white loop of suspension line that is routed through the 3-rings. Quote Share this post Link to post Share on other sites
