skydive4play
cypres batteries
http://www.cypres-usa.com/cyp16.htm Dated 1995.
When does the battery need replaced? Airtec requires that the batteries be replaced the first time the low battery error code (8998/8999) is encountered during self-test, or every two years, or every 500 jumps, which ever of these occurs first. Note that the two year period is from the date of last battery change. The date of the last battery change can be found on an orange label on the cable end of the black plastic processing unit box. As this is packed inside the reserve container, it is necessary for riggers to check out the battery date as part of the reserve inspection / repack.
It is a good idea for all riggers to have some extra CYPRES batteries in stock to avoid extra delays and shipping costs. When stored as instructed the batteries have a long shelf life; the two year period does not start until they are installed.
Pull.
