travisjones 0 #1 June 19, 2016 Going light speed with Aura 2 and electric Jetpack. More jumps and flysight data soon. Squirrel Rocks! Enjoy https://www.youtube.com/watch?v=YUefaW9jdRw Quote Share this post Link to post Share on other sites
piisfish 140 #2 June 19, 2016 Interesting. How happy are you with the results ?scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
roostnureye 2 #3 June 20, 2016 1:13 on an aura2!!!!! you go lol!Flock University FWC / ZFlock B.A.S.E. 1580 Aussie BASE 121 Quote Share this post Link to post Share on other sites
keithbar 1 #4 June 21, 2016 roostnureye 1:13 on an aura2!!!!! you go lol! I will bet that just adds drag. Hell I did 2:13 just yesterday. I in my Raptor. And I'm like 285 pushing three hundred out the door.. right Jeremy ?i have on occasion been accused of pulling low . My response. Naw I wasn't low I'm just such a big guy I look closer than I really am . Quote Share this post Link to post Share on other sites
unclecharlie95 3 #5 June 21, 2016 Nice work Travis I have a feeling you are the first but many others will follow. Vesa proved the concept but the hardware was problematic. New battery and motor technology make a "useful" system affordable and safe. Having the 'thrust' closer to your body / CofG will help, perhaps even inside the leg wing?BASEstore.it Quote Share this post Link to post Share on other sites
verticalflyer 11 #6 June 21, 2016 Be very interesting to see the data, ignoring time since am guessing you only did a limited test window to give you margins in case anything went pear shaped. Any early insights into additional forward speed from thrust?Dont just talk about it, Do it! Quote Share this post Link to post Share on other sites
WickedWingsuits 0 #7 June 21, 2016 +1 on the drag, but I think it is all good stuff to play around with because the future is in there somewhere. Looks fun too!Summer Rental special, 5 weeks for the price of 4! That is $160 a month. Try before You Buy with Wicked Wingsuits - WingsuitRental.com Quote Share this post Link to post Share on other sites
johnmatrix 21 #8 June 21, 2016 Now this is what the wingsuit forum is for! Awesome!! Quote Share this post Link to post Share on other sites
photognat 0 #9 June 21, 2016 That's really cool, but I don't see how the math can work based on currently available hardware. You'll need >= 200lbs of thrust to be able to maintain level flight with a GR of 2.5-3:1 (which will drop due to all the extra drag & weight). It looks like you're using a DS-94, so let's say you've got 30lbs of thrust. So you'd need at least 4 of those to actually start seeing something resembling powered flight. There are units that can give you almost 50lbs of thrust (TF-8000, 14S, 140mm fan), but you'd need a couple of them and at 17kw (22 horsepower!) each you'll need a 320A+ ESC and a 15AH 14S battery (about 20lbs all together) for each one to have enough power for 2 1/2 minutes of flying (and some reserve so you don't kill the batteries). Then you've got multiple 22HP engines close to your body spinning a blade at 50,000RPM that was designed to go on a toy. For this to be viable with a single EDF the fan needs to be much bigger, maybe 250-300mm. Right now there's nothing like that on the market but I'm sure there will be in another 5-10 years. Quote Share this post Link to post Share on other sites
WickedWingsuits 0 #10 June 21, 2016 I guess it they were mounted in the leg wing it would reduce drag and get the spinny parts away from the critical body parts!Summer Rental special, 5 weeks for the price of 4! That is $160 a month. Try before You Buy with Wicked Wingsuits - WingsuitRental.com Quote Share this post Link to post Share on other sites
photognat 0 #11 June 21, 2016 Maybe, problem is you need the intake directly exposed to the airstream and the exhaust can't have anything blocking it. You also don't want flapping nylon around the hot bits. Then you have possible thrust vector/control issues with the thrust coming from aft CG. Quote Share this post Link to post Share on other sites
travisjones 0 #12 June 25, 2016 Im jumping it again today. I agree on the level flight thing and thats not what im going for. I am going for speed. The jump was fast i will not deny it. But in fact i got a slightly better glide angle at a very high speed 200mph. That is why the jump was so short. I covered the same distance and angle just much faster. I am very pleased with the results. I am building it for base jumping so anything over a few minutes of power is not necessary for me. Like it or not. Its super fun. My friends trying to film said i was out ahead at the same glide but pulling away. No chance on them catching up. Quote Share this post Link to post Share on other sites
travisjones 0 #13 June 25, 2016 Schuebeler Jets has a new unit coming out that i have to sign a waiver for and present a safety plan but it produces over 60 lbs and a very high speed. When i hit the button on my ds-94 i can feel a little power my my goal has been to go bigger once im use to the baby motor. Quote Share this post Link to post Share on other sites
travisjones 0 #14 June 25, 2016 You have a weak mind. Yes it was faster but not straight down you dummy. Quote Share this post Link to post Share on other sites
photognat 0 #15 June 25, 2016 Ah, sick! That thing would rip on a C-Race. Setup for speed instead of glide is an interesting choice for BASE. Good luck, looking forward to seeing it here in Brento :) Quote Share this post Link to post Share on other sites
megamalfunction 1 #16 July 14, 2016 Boots are probably the way to go. https://www.youtube.com/watch?v=8HMdioj6kng Quote Share this post Link to post Share on other sites
jstockdale 0 #17 July 24, 2016 For anyone following along, Geo Robson was the furthest along on powered wingsuit flight. He had done aerodynamics calculations based on the V3 that showed longitudinal instability in the powered flight modes. You can read more here: http://raffaello.name/wp-content/uploads/2013/09/AIAA-237998-291.pdf The take away, is that without vectored thrust, it may not be possible to maintain stable flight, regardless of the thrust you throw down. Geo suggested active thrust vectoring to make the aerodynamics work. I haven't seen anyone do any mathematically vigourous work since he went in, but I expect naive applications of thrust to have the same issues in a modern suit as he saw in the V3. Quote Share this post Link to post Share on other sites
johnmatrix 21 #18 July 24, 2016 Wow - thanks for the post. :) Quote Share this post Link to post Share on other sites
kallend 2,231 #19 July 24, 2016 photognatThat's really cool, but I don't see how the math can work based on currently available hardware. You'll need >= 200lbs of thrust to be able to maintain level flight with a GR of 2.5-3:1 (which will drop due to all the extra drag & weight). How did you come up with that 200lbs figure? I make it more like 80lbs. At my exit weight, with 200lbs I could hover.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
kallend 2,231 #20 July 24, 2016 WickedWingsuits I guess it they were mounted in the leg wing it would reduce drag and get the spinny parts away from the critical body parts! The LiPo batteries get quite hot too. (and have been known to explode).... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
photognat 0 #21 July 25, 2016 2 things: Travis' size and the amount of thrust Yves is working with. Unless you weigh 80lb or 90lbs, I'd be very surprised if 80lbs of thrust is enough to maintain level flight. Once you add all the weight and have the EDFs sticking out, your L/D is not gonna be 3:1. Additionally, all thrust quotes are based on static thrust. As you approach your EDF's efflux speed (probably 190-220mph), your thrust drops to 0. That's the main reason Yves has to use a turbine, an EDF simply won't allow him to fly faster than ~170mph. You're also going to want to over-rate all of your hardware so you don't run it at 100% all the time. 80lbs of thrust is considered about the very minimum to fly a paramotor with a paraglider that has a 7:1 glide ratio, and that's at 30mph. You might be able to stay level with an Aura 2 pulled up in a stall at 70mph, but that's about it. Quote Share this post Link to post Share on other sites
kallend 2,231 #22 July 25, 2016 photognat2 things: Travis' size and the amount of thrust Yves is working with. Unless you weigh 80lb or 90lbs, I'd be very surprised if 80lbs of thrust is enough to maintain level flight. Once you add all the weight and have the EDFs sticking out, your L/D is not gonna be 3:1. Additionally, all thrust quotes are based on static thrust. As you approach your EDF's efflux speed (probably 190-220mph), your thrust drops to 0. That's the main reason Yves has to use a turbine, an EDF simply won't allow him to fly faster than ~170mph. You're also going to want to over-rate all of your hardware so you don't run it at 100% all the time. 80lbs of thrust is considered about the very minimum to fly a paramotor with a paraglider that has a 7:1 glide ratio, and that's at 30mph. You might be able to stay level with an Aura 2 pulled up in a stall at 70mph, but that's about it. So where is the math you claimed to have used? All of the above is just speculation.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
photognat 0 #23 July 25, 2016 http://lmgtfy.com/?q=edf+efflux+speed+vs+thrust Quote Share this post Link to post Share on other sites
kallend 2,231 #24 July 25, 2016 photognathttp://lmgtfy.com/?q=edf+efflux+speed+vs+thrust And NOTHING in there applies to the L/D ratio of a wingsuit, or applies in any way to wingsuit flying at all. It appears that YOU haven't actually done the appropriate math/physics at all.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
photognat 0 #25 July 26, 2016 Let me put it in simpler terms that even a professor can understand: At trim speed in a wingsuit your actual thrust will be 30-50% of what the EDF is rated at. Quote Share this post Link to post Share on other sites
