gus
Stiffened risers
I'd always thought that risers stiffened where the top of the brake toggle goes in to its elastic keeper would be a good idea - to make it more difficult for the riser to flex and pop the toggle. Then I noticed recently that my Gargoyle's risers have exactly this and maybe other BASE risers do too.
Is it overkill for skydiving risers or is there another reason that it's not done?
Gus
OutpatientsOnline.com
so true, but bulk vs. safety.
it's almost like cool vs. safe.
Unless that extra bulk is causing a problem with safety...like forcing riser covers open, or catching up the slider grommet on a hard opening because of the extra bulk. Both of which I've personally seen happen on Mirage rigs with the new style toggle keepers.
"...and once you had tasted flight, you will walk the earth with your eyes turned skyward.
For there you have been, and there you long to return..."
I was having the occasional popped toggle, either after opening or by knocking it when steering with my rear risers just after opening. I had the elastic replaced with new/tighter elastic, while getting a line set replaced, and have had zero popped toggles since then, in ~160 jumps. The elastic is tighter than originally, if I can recall that far back.
My buddy just recievced a new set of mirage risers and I could get the toggle to pop in my hands with only a slight flex in the direction they would go over your shoulder. He sent them back.
It seemed the the bottom toggle keeper held tighter than the top one and because they went in opposing directions, there was no slack to allow and flexing of the riser.
Johnny
--"This ain't no book club, we're all gonna die!"
Mike Rome
how can extra bulk at toggles force riser covers to open. when packed correct, toggles are at the bottom of reserve sides, and nut under tuck tabs, where bulk would cause a problem.
What do you mean by that, i can pull my slider over my toggles without a problem, so i guess toggles don't catch my grommet?
My buddy just recieved a new set of mirage risers and I could get the toggle to pop in my hands with only a slight flex in the direction they would go over your shoulder. He sent them back.
How can that be? the toggles are not over you shoulder but at the sides of the reserve. so they are not bent but straight, and safely covered with riser covers. and even if you would bend them over the shoulder the way it's supposed to be packed (toggle is turned down, when over shoulder, not up right?), the toggles would be even more firmly tucked, because upper and lower part would be squeezed together, so i don't see how is it possible to pop the toggle by bending the riser.
you can see the toggles here http://www.miragesys.com/order/parts/toggles.html
The one that i'm talking about are on the left. They are tucked from above and from below, so no matter in which direction they are pushed (by slider or wind) the stay tucked, unles you pull them.
Well that's my opinion. If anyone doesn't like them so be it, it's your opinion, and mine opinion is mine. :)
"George just lucky i guess!"
I know once packed they are straight, but the ease that they popped on the top was the problem. Any handling of the riser could have caused it to pop. Even grabbing the risers on opening. The bottom keeper was tighter causeing the top one to give way first. Personally I think the bottom keeper is almost unnecessary, except for keeping the toggle from flapping around. The top of the toggle is what must be secure. I dont know why they made the bottom so tight.
Johnny
Mike Rome
Hey man, you're entitled to whatever opinion you want, but it's certainly possible to have any and all of these problems occur on the magic Mirage risers, I assure you.
Riser length determines where the toggles lay in the pack tray. Shorten the risers, and the toggles move up in the pack tray...eventually running into the riser covers. It doesn't take much to start applying pressure on the riser covers either. Sometimes as little as 2 inches of change can be a problem. There are other ways this can happen as well...
With the extra bulk of the Mirage style double tuck toggles, the slider grommet that came down further than it was supposed to and twisted slightly was lodged tightly against the toggle... The toggle couldn't be freed, not could the slider be easily moved. The jumper was able to free it eventually, but it took quite a bit of time, and probably wouldn't have occurred on a less bulky set-up.
The fact is, there are several different styles for just about every part or piece of a rig. Some look better than others...some are marketed better than others...some simply are better than others. But this is all based on your experiences and frame of reference. No one is telling you what to believe, but you'd be a bit of a fool not to at least acknowledge that there are things that can happen that you a) may not have heard of or b) may not have had happen to you personally.
Keep an open mind. You'll live longer...
