fastkite 0 #1 January 24, 2013 Attached is a photo of my new FligthHUD mounted in my G3 Cookie helmet - not flight tested due in part to the -20C temperatures outside. It's adjustable for different eye heights, flexible so you can charge the unit, battery fits nicely at the back of the helmet. Quote Share this post Link to post Share on other sites
Shredex 0 #2 January 24, 2013 Think you forgot to hit "upload" after you attached the image. Quote Share this post Link to post Share on other sites
fastkite 0 #3 January 24, 2013 I think it worked now, sorry Quote Share this post Link to post Share on other sites
dsteed7221 0 #4 January 24, 2013 You figure out how to "zero" the altitude yet? Quote Share this post Link to post Share on other sites
colossus 0 #5 January 24, 2013 Can you post some more pictures? How did you set it up in the G3? What mods did you have to do to get it in there? Quote Share this post Link to post Share on other sites
kallend 2,231 #6 January 24, 2013 QuoteAttached is a photo of my new FligthHUD mounted in my G3 Cookie helmet - not flight tested due in part to the -20C temperatures outside. It's adjustable for different eye heights, flexible so you can charge the unit, battery fits nicely at the back of the helmet. Did you have much trouble re-locating it from the bugeye goggles? Anything you learned that might be useful for others who wish to do this?... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
fastkite 0 #7 January 24, 2013 I'll post some photos soon. I'm in the process of creating a removable version which is soft enough that it won't scratch the visor over time. It was not all that difficult to locate the eye position. At least no more fussy then getting the goggles to work for your head. In some variations I was able to locate the eye piece closer to my face (touching) making the optical illusion of heads up even better. By installing this in your helmet you loose peripheral vision to the right as if you were wearing the goggles, but at least your left vision is still intact. Once I have the kinks worked out and flight test it. I may created a limited number of them for those who aren't interested in attaching it themselves. Quote Share this post Link to post Share on other sites
mccordia 74 #8 January 24, 2013 Quote By installing this in your helmet you loose peripheral vision to the right as if you were wearing the goggles, but at least your left vision is still intact. So in short, you loose depth perception. Recommendable to only rig that way in a skydiving environment. Depth perception may be a handy feature of our eyeballs in the base environment JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
ifell 0 #9 January 24, 2013 Quote Quote By installing this in your helmet you loose peripheral vision to the right as if you were wearing the goggles, but at least your left vision is still intact. So in short, you loose depth perception. Recommendable to only rig that way in a skydiving environment. Depth perception may be a handy feature of our eyeballs in the base environment Just fly 8inches higher than you normally would Quote Share this post Link to post Share on other sites
fastkite 0 #10 January 24, 2013 Well you loose more depth perception with the FlightHUD goggles, so if it concerns you. I would suggest not wearing FlightHUD at all. The issue is the FlightHUD screen & electronics sits to the right of your eye blocking some of your vision. While the lens and mirror sit just below your eye blocking a little more. I don't think I would BASE jump with or without FlightHUD, but that's just me. Quote Share this post Link to post Share on other sites
dthames 0 #11 January 24, 2013 Can the display be used with the left eye and not be seen inverted? I am not familar with the goggles but have been curious of it could be switched over to the left eye.Instructor quote, “What's weird is that you're older than my dad!” Quote Share this post Link to post Share on other sites
killis 0 #12 January 25, 2013 No, this is not possible. See the pictures I posted at the bottom of this page to see why. Quote Share this post Link to post Share on other sites
fastkite 0 #13 January 26, 2013 Well I got it pretty well figured out. I've managed to make it removable, adjustable and you can still put the HUD back in your goggles without any problems. I'll post some photos shortly. Quote Share this post Link to post Share on other sites
kallend 2,231 #14 January 26, 2013 QuoteWell I got it pretty well figured out. I've managed to make it removable, adjustable and you can still put the HUD back in your goggles without any problems. I'll post some photos shortly. Excellent, thanks in advance.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
fastkite 0 #15 January 29, 2013 Attached is a photo of the finished Cookie G3 HUD Mount. I've made a couple of them, waiting on a supplier to get the raw materials to make more. It's adjustable in several ways the goggles are not. You can move the screen up and down in your vision depending how prevalent you want the HUD to be. The HUD battery fits nicely in the audible pocket by routing it around the visor hinge, or can be mounted at the back for those that use two audibles. No modifications to the G3 Cookie or HUD are required. An extra thin specialize yet stronger velcro strip is applied to the HUD body. This does not interfere with the goggle mount so you can return your HUD to it's original goggles at any time. The mounting band is attached to the G3 Cookie by mating to the existing velcro strips. You can easily access all the HUD controls (Power button, USB port, lens adjustment) while the HUD is mounted in your helmet with the visor open. -Joe Quote Share this post Link to post Share on other sites
piisfish 140 #16 January 29, 2013 and there goes half your right side vision scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
kallend 2,231 #17 January 29, 2013 Quote and there goes half your right side vision You must already have tunnel vision if that constitutes 1/2.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
GobbleGobble 0 #18 January 29, 2013 Quote Quote and there goes half your right side vision You must already have tunnel vision if that constitutes 1/2. It looks like a significant chunk of peripheral vision is lost. No need to be a dick all the time. Quote Share this post Link to post Share on other sites
kallend 2,231 #19 January 30, 2013 Quote Quote Quote and there goes half your right side vision You must already have tunnel vision if that constitutes 1/2. It looks like a significant chunk of peripheral vision is lost. No need to be a dick all the time. Well, don't be one then. Apparently you have a problem with precision in language.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
WickedWingsuits 0 #20 January 30, 2013 I will take one when you have the parts. It is an improvement over the goggles because you get your left peripheral vision back!Summer Rental special, 5 weeks for the price of 4! That is $160 a month. Try before You Buy with Wicked Wingsuits - WingsuitRental.com Quote Share this post Link to post Share on other sites
uberchris 0 #21 January 30, 2013 next step is to build a helmet/HUD with a visor integrated with LED technology and a microchip that presents all your data right inside your clear visor..........how nice would that be? and how expensive, id imaginegravity brings me down......... Quote Share this post Link to post Share on other sites
kallend 2,231 #22 January 30, 2013 'll take (buy) one too. Thanks.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
luferbu 0 #23 February 15, 2013 I'll get one too! Thanks! Quote Share this post Link to post Share on other sites
fastkite 0 #24 April 8, 2013 I created a video showing the installation of the Cookie G3 FlightHUD mount. http://www.youtube.com/watch?v=Hc7sQCkRoCg -Joe Please review the rules on advertising and selling items in the forums. Quote Share this post Link to post Share on other sites
kallend 2,231 #25 April 8, 2013 QuoteI created a video showing the installation of the Cookie G3 FlightHUD mount. www.youtube.com/watch?v=Hc7sQCkRoCg -Joe Made clicky.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
