jayrech 0 #1 March 15, 2012 Curious if any one has any experience with the Performance foam on the leading edge of arm wings (Phantom 3). I believe this is a new option for the Phantom and has been offered on larger wings. Is it worth the extra 50 bucks? Thanks for the input in advance.D.S 174.2 Be careful what you say. Some one might take it the right way. Quote Share this post Link to post Share on other sites
BMichaeli 1 #2 March 15, 2012 I think it is like the foam on the leading edge of tony suits. It is designed to keep the leading edge from deforming so it can maintain optimal shape while flying. I could be wrong though i have not seen it. Quote Share this post Link to post Share on other sites
LukeH 0 #3 March 15, 2012 Worth is very subjective, and will depend on how you use the suit. If you are just flocking with your friends I doubt you'll need it, but if you are interested in getting some extra performance at the top end I think the foam will provide it. I don't have back to back jumps with and without the foam to compare, however I did notice a long time ago that I seemed to have better flights when wearing a heavy fleece than in a t-shirt. It could have been all in my head, but it seemed to make enough of a difference that I noticed it. I'd expect the foam to have a greater effect and it would be worth €50 to me. Quote Share this post Link to post Share on other sites
Butters 0 #4 March 15, 2012 QuoteI think it is like the foam on the leading edge of tony suits. Are you aware of the difference between the leading edges of Phoenix-Fly and Tonysuits? It's probably similar to Phoenix-Fly's other suits (and nothing like Tonysuits) ..."That looks dangerous." Leopold Stotch Quote Share this post Link to post Share on other sites
BMichaeli 1 #5 March 15, 2012 QuoteQuoteI think it is like the foam on the leading edge of tony suits. Are you aware of the difference between the leading edges of Phoenix-Fly and Tonysuits? It's probably similar to Phoenix-Fly's other suits (and nothing like Tonysuits) ... Apparently not. What is the difference? What I was trying to compare is in Tony suits their is a foam dowel rod thing in the arm to prevent it from deforming or at least that's how it was explained to me. Is that not right? Quote Share this post Link to post Share on other sites
dirtbox 0 #6 March 15, 2012 never jumped a PF suit with it but I am familiar with it (got to rotate it on a V4 in the plane when it had inversed and checked a few suits out on the ground with it) and my tony suit has its version ... the basic principal is the same, which is to maintain the wing shape better. Tony uses tubular foam (and neoprene on some suits) that sits above the arm and PF uses shaped foam that conforms to the arm shape - both raise the leading edge slightly above the arms and are there to add the shape, the rest is semantics really. is it worth it? If it makes you feel happy get it. I'd argue that unless you're one of the 10 best wingsuit pilots in the world you would get more out of technique and training jumps than the foam will give you and even then it would still be minimal. Be it Tony, PF, Alien et al, it is only a suit, you still have to fly it Quote Share this post Link to post Share on other sites
Butters 0 #7 March 15, 2012 QuoteI'd argue that unless you're one of the 10 best wingsuit pilots in the world you would get more out of technique and training jumps than the foam will give you ... Agreed. The performance foam appears to be removable so if you get it and don't like it you can remove it. Is it worth it? Performance, I don't know. Preference, I liked it on my Vampire 3 and wished I had it on my Phantom 2."That looks dangerous." Leopold Stotch Quote Share this post Link to post Share on other sites
Migs 0 #8 March 15, 2012 If you look at the second figure on the link bellow... you will see a bit of what manufactores are actually trying to achive with the added pad on the leading edge of the wing. Air Foil~Migs~ On Facebook Quote Share this post Link to post Share on other sites
Butters 0 #9 March 15, 2012 Quote If you look at the second figure on the link bellow... you will see a bit of what manufactores are actually trying to achive with the added pad on the leading edge of the wing. Air Foil I believe Phoenix-Fly is actually trying to achieve the first figure. That whole "Need 4 Speed" thing ... "That looks dangerous." Leopold Stotch Quote Share this post Link to post Share on other sites
jakee 1,622 #10 March 15, 2012 QuoteQuoteQuoteI think it is like the foam on the leading edge of tony suits. Are you aware of the difference between the leading edges of Phoenix-Fly and Tonysuits? It's probably similar to Phoenix-Fly's other suits (and nothing like Tonysuits) ... Apparently not. What is the difference? What I was trying to compare is in Tony suits their is a foam dowel rod thing in the arm to prevent it from deforming or at least that's how it was explained to me. Is that not right? The solid foam in Phoenix suits (at least in the V-range) is cut and shaped to sit over your arm and form the leading edge of the wing. The solid foam in a Tony suit is a long round baton. At the end of the day they are very similar in function, but the Tony version is a simpler copy.Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites
splat123 0 #11 March 15, 2012 I find it makes it easier to zip arm wings up/down with foam Quote Share this post Link to post Share on other sites
jayrech 0 #12 March 15, 2012 Thanks alot for all the info! Lots of good points brought up! I wil go with the fancy foam to make fly like one of the top ten :D Thanks again!!D.S 174.2 Be careful what you say. Some one might take it the right way. Quote Share this post Link to post Share on other sites
kallend 2,188 #13 March 15, 2012 QuoteI find it makes it easier to zip arm wings up/down with foam I venture a guess that THAT is the main benefit.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
imsparticus 0 #14 March 16, 2012 QuoteI find it makes it easier to zip arm wings up/down with foam this seems to be the foams primary function in the tonysuit every video i see of a tonysuit in a dive shows the leading edge colapsed and usually flailing towards the baggy escape sleeve with the foam doing nothing for overall form. though the initial part of the leading edge in the tonysuit does seem to be sharper with their foam weather this is an advantage at the speeds we fly i dont know. Quote Share this post Link to post Share on other sites
mccordia 74 #15 March 16, 2012 On all PF suits that offer the Performance Foam, its main function is to provide a smooth leading edge and also marry the sleeve nice and tight against the arm. The foam is cut on the inside to match the curve of the arm so all moves with the arm also translate directly to the wing and there isnt a delay due to a loose fit. The attached picture of a Venom shows how the leading edge looks in flight. Even with a sub-optimal arm position, like a slightly bent elbow (not in the attached pic) the leading edge will look clean. I have quite a few jumps on the Phantom3, Shadow2, Venom and a few other new things we're working on, and in all I personally prefer the feel (thats even outside of the actual performance gain) of the foam inserts over that of a normal sleeve. It seems to make my flying a lot more crisp and clean. Combined with the good inflation it also seems to relieve a bit of pressure from the arm in terms of keeping it open/stretched on longer flights. Here is a clip of the shadow2 with the same performance foam option http://www.youtube.com/watch?v=hU1x4c0EED4JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
BIRDDOCTOR 0 #16 March 16, 2012 I agree with Jarno. I have about 20 jumps on my P3 (with performance foam) and feel overall the suit flies more precise in addition to a slight performance gain.Base# 1638 Quote Share this post Link to post Share on other sites
jpengel 0 #17 March 16, 2012 How noticeable is this performance foam? I got my p3 and forgot if I got that option. My arm sleeves have about 1/4" to 1/2" soft foam sewed in, nothing removeable. Quote Share this post Link to post Share on other sites
BIRDDOCTOR 0 #18 March 16, 2012 Yes, the foam is non-removable, but nice b/c it stays in place and does not rotate easy. I noticed a slight performance gain on runs trying to max out horizontal speed. The arm wing to me felt more solid at speed.Base# 1638 Quote Share this post Link to post Share on other sites
kallend 2,188 #19 March 16, 2012 If you really want to see if there's a difference, fly with the foam removed from one side, and see if you notice any asymmetry in the flight behavior.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
jakee 1,622 #20 March 16, 2012 QuoteI got my p3 and forgot if I got that option. If you had it you'd know.Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites
mccordia 74 #21 March 16, 2012 QuoteYes, the foam is non-removable The foam is actually easily removable. There is a double layer of fabric you can peel back, which than allows for sliding the foam out of the pocket. Its in there tight, but its easily remove-able.JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
