cocheese 0 #1 November 20, 2011 A little shark fin near the feet in the center might increase stability and reduce flat spins. Can somebody try this? Quote Share this post Link to post Share on other sites
DSE 5 #2 November 20, 2011 I'd be happy to try it, but nickels to nuggets, it would probably either: A-do nothing except induce drag B-induce greater instability due to constantly shifting position. Legs aren't like horizontal stabs where they're rigid, they're constantly moving, so the vertical "stabilizer" would be anything but stable. Remember the old XS wingsuits with the "winglets" made out of half a pancake turner? They didn't accomplish anything except looking goofy. Worth playing with tho. Flatspins are the order of the day at E right now anyway. Quote Share this post Link to post Share on other sites
cocheese 0 #3 November 20, 2011 I think it can be made to work.Putting a fin on the bottom may help too. Rocket fins Quote Share this post Link to post Share on other sites
WickedWingsuits 0 #4 November 20, 2011 I feel that the material between knee and toe when stretched acts the same as an inverted V tail. It can be used both in macro and micro movements for all sorts of control inputs. http://salempress.com/store/samples/encyclopedia_of_flight/encyclopedia_of_flight_tail.htm I also think it is good to try new and crazy ideas...because you never know what little nugget of revolution you will get from it.Summer Rental special, 5 weeks for the price of 4! That is $160 a month. Try before You Buy with Wicked Wingsuits - WingsuitRental.com Quote Share this post Link to post Share on other sites
mccordia 74 #5 November 20, 2011 In case of asymetry or bent legs, I could also see a stabilizer like that powering/adding to instability/turn direction. Seeing as most big surface wingsuits don't have full airflow over the lower legwing, the only place where such a tail/rudder would have effect would be the bottom section. Which is the exact place where it would mostly contribute to drag as well (judging how thick it would have to be, if you want it to be made of inflating materials). The only suits seemingly needing such a stabilizer would be the 'square' shaped ones that are known for stability issues. Why not look other directions than 'upsizing' and creating 'fixes' for the instability such upscaling gives us?JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
DSE 5 #6 November 20, 2011 Why modify the suit at all? For 50.00, we could have strap on fins! Certainly worth playing with, but I'd hold my bet that any additional, vertical drag on the back end is only going to add to/instigate instability. I know that Yuri and Jarno are totally into strap-ons... These'll sell big! A new place to put skydiving stickers, too! Quote Share this post Link to post Share on other sites
KrisFlyZ 0 #7 November 20, 2011 Pressurized's literature talked of a vertical stabilizer between the butt wing and the leg wing on their suit(can't remember the name). I think a few were even made. Quote Share this post Link to post Share on other sites
granpasc 0 #8 November 20, 2011 Never see a vertical fin on any bird ...But almost all fish near center of gravity Quote Share this post Link to post Share on other sites
imsparticus 0 #9 November 20, 2011 I believe that ducting of air between legwing and rear deflector (ie vampires and skyfliers) does a similar thing to a vertical stab. while i hear alot of complaints about yaw instability on the bigger suits without especially when trying to fly fast. Quote Share this post Link to post Share on other sites
cocheese 0 #10 November 20, 2011 Looks great.Joking aside, I know when I fly wings (r/c planes) with no fins, the roll rate is great until the unrecoverable flat spin happens. Try using coroplast for prototypes then cover them in cloth. Hardly any drag at all. Maybe your fin idea on the feet would work good if they faced the bottom side of the wing suit. Quote Share this post Link to post Share on other sites
piisfish 140 #11 November 20, 2011 Quote Maybe your fin idea on the feet would work good if they faced the bottom side of the wing suit. my fin of the bottom side makes me turn left a bit, plus with the cold of the jumps, it is subject to shrinkage scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
phoenixlpr 0 #12 November 20, 2011 Quote A little shark fin near the feet in the center might increase stability and reduce flat spins. Can somebody try this? Have you ever though that we should jump with a church-bell attached to our suit? That could be also beneficial for several reasons. Quote Share this post Link to post Share on other sites
cocheese 0 #13 November 20, 2011 maybe more cowbell, but no, what the hell are church bells good for?Have you ever thought of turning a wingsuit into an inverted airplane for better performance? Quote Share this post Link to post Share on other sites
Calvin19 0 #14 November 20, 2011 QuoteWhy not put a vertical stabilizer on a wing suit? Because It seems that it's been a lot easier to just avoid getting into a spin. I don't think the wingsuit needs any more drag. Quote Share this post Link to post Share on other sites
cocheese 0 #15 November 20, 2011 So flat spins aren't an issue... even for beginners? Sorry I'll go back to the bon fire. Quote Share this post Link to post Share on other sites
mccordia 74 #16 November 20, 2011 Quote So flat spins aren't an issue... even for beginners? Noop...they are not. When they are not put in a huge wingsuit, and when they get an actual proper briefing on what to do. No issue at all. Similar to a line-over for an AFF student. Its for sure an annoying thing to happen. But its not an issue that warents a change in gear design. It just means students need good training. Similar to big suits. When you fly a big suit, make sure you have the training AND experience, and you should be able to deal with anything. If you can't. uhm...jump a smaller wingsuit?JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
MrCat 0 #17 November 21, 2011 Rather than looking at fish / sharks / planes with a vertical stabiliser above the body where the optimal positioning for a vertical stabeliser would be comprimised by the placement of our rigs perhaps we should be looking at yacht design where the stabiliser is under the body of the vessel? From a functional point of view it would be unlikely to become a problem on deployment regardless of size allowing for different configurations/larger sizes etc Thoughts ?Jump more, post less. Quote Share this post Link to post Share on other sites
mccordia 74 #18 November 21, 2011 QuoteFrom a functional point of view it would be unlikely to become a problem on deployment The legwing and asymetry can already cause linetwist/spinning around of the body. Now imagine this with another added surface..JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
piisfish 140 #19 November 21, 2011 if you are unstable in your wingsuits, get some serious coaching, and smaller suits. scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
mccordia 74 #20 November 21, 2011 Quote if you are unstable in your wingsuits, get some serious coaching, and smaller suits. No man! Upsize for safety!JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
piisfish 140 #21 November 21, 2011 Quote Quote if you are unstable in your wingsuits, get some serious coaching, and smaller suits. No man! Upsize for safety! and wear a weightbelt for speed (which I would need to consider to fly more comfortably at 90-100km/h vertical)scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
MrCat 0 #22 November 21, 2011 Quote Quote From a functional point of view it would be unlikely to become a problem on deployment The legwing and asymetry can already cause linetwist/spinning around of the body. Now imagine this with another added surface.. Or just imagine that it was called a cod piece.... I may not have been taking the thread entirely seriously Jump more, post less. Quote Share this post Link to post Share on other sites
kallend 2,188 #23 November 21, 2011 Quote Never see a vertical fin on any bird Have you never watched a grackle in flight? www.jrcompton.com/photos/The_Birds/J/May-08/grack-abstract-fly-w-vert-tail_J217008.jpg www.jrcompton.com/photos/The_Birds/J/May-08/grackle-flying-w-vertical-tail+_J217001.jpg www.arthurgrosset.com/sabirds/photos/quinig12776.jpg elibrary.unm.edu/sora/Wilson/v093n04/p0500-p0505.pdf... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
virgin-burner 1 #24 November 21, 2011 Quote Rather than looking at fish / sharks / planes with a vertical stabiliser above the body where the optimal positioning for a vertical stabeliser would be comprimised by the placement of our rigs perhaps we should be looking at yacht design where the stabiliser is under the body of the vessel? From a functional point of view it would be unlikely to become a problem on deployment regardless of size allowing for different configurations/larger sizes etc Thoughts ? that would give us guys a place to put our huge cocks too; and the girls a place to store their strap-ons! “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
kallend 2,188 #25 November 21, 2011 Quote that would give us guys a place to put out huge cocks too; Why would you want to put it out? Is it on fire?... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
